Outlaws
I think all three sound good and usable. (that should solve this debate lol. None of them stick out as obvious this or that, and none of them suck IMO)
amra said:Okay, here are my entries for this shootout.
First a couple of things:
1. I didn't have the means to record once and then re-amp the signal, so each recording is a different take and because of that, played a little different.
2. This is metalheds riff - and it is not really my style of playing (my style is slower and sludgier), so forgive the rough playing. I just listened to his riff and played it from memory (yours was in D tuning right metalhead?), and I kinda rushed through it
I did things a little different. There are 7 short clips. The clips are recordings of either a V-AMP Pro, a Randall Solid State combo, or a Laney 100 watt tube amps, all using various settings. Not knowing which, decide which you like best for a modern metal tone. The V-AMP was recorded direct, and the other two amps were recorded with a SM57 stuck an inch off the speaker grille, into a Focusrite Penta Platinum preamp. The audio interface is an M-Audio Delta 1010LT. There is a text e at the end of the list that gives the answers regarding what is what. Listen to the clips a few times before you read it, if you would.
Here is the link already!
Outlaws said:I don't get it....after looking at the answers, did you use the Vamp modeler into the Laney?
metalhead28 said:When I recorded the 5150 I wanted to showcase the fat midrange and the tightness that the others will not achieve. I really don't think it's a great sound by itself, but the other two amps are absolutely not capable of sounding anything like that. That's my point. This sound would work great if it was doubled up with another more saturated tone.
The modeler sounds alright on it's own. Mind you that the mids and treble are cranked all the way up on that thing. That is just how it sounds. It gets washed out in a mix really easily. That's one of the things I hate about it. Plus it has a certain graininess to the sound that annoys the hell out of me.
amra said:That's not a very fair test. The V-AMP or any modeler in fact, sounds like ass with the mids and treble cranked all the way up. Especially when compared against a tube amp with the mids and low mids accentuated, and the highs rolled off. Very slanted comparison, man... doing it the way you did it was a sure way to get everyone to notice the tube amp, even if it was a completely wrong distortion for metal. I thought the idea here was to get some good metal tones, not try to make a sound that sounds as tubey as possible.
P.S. You can make a solid state amp AND a modeler sound like your 5150 if that is the test - to make everything sound mid-rangy and tubey.
