C
carter238898
First off, thank you for any help you guys can give.
I've been using Cool Edit Pro for years now and am quite comfortable with all of its features, effects, menus etc. I like its simple interface.
I recently bought a Line6 TonePort UX2 to use as an interfaceamp replacement, but Cool Edit Pro doesn't support the ASIO drivers the the TonePort uses cause it's so old LoL.
I'm thinking of using a different program to record and then import those saved tracks into Cool Edit to add effects and mix/master and what-not.
Questions is this:
What program would be good to do the recording? Need a program that supports the ASIO drivers and is compatible with Vista.
Also, does anyone know of another program that is simple to use that could possibly do both, the recording, multi-tracking and effects?
Thanks so much for your time.
Questions is this:
Does anyone have a set-up using a TonePort with Audacity or Reaper?
