M
mkaranth
i use cool edit for recording vocals, guitars and bas. wat is the best software for drums programming???? wny ideas??? what abt cakewalk???
minofifa said:if you have a sequencing program that supports vsti plugins, give BFD serious consideration. It is a sample library of tons of drums, check it out at www.fxpansion.com
minofifa said:hey Genob. good to know someone currently using it. how do you find programming drums in general? is it tedious or efficient? are there premade patterns that you can tweak?
)genob said:Programming drums can be tedious.... I take my time when doing drums.. I always sit there and pretend i'm playing them so I know not to write drums as if I had 5 hands... (hitting cymbals, toms, and snare at the same time is bad...)
I don't use premade patterns because I usually have to deal with wierd changes and things like that. There are a bunch of premade grooves out there to get started with if you don't want to get into writing custom drums.
BFD is a nice program to use. It has a few flaws that can be worked around...
What I usually do is, I write the drums in cakewalk using a general midi package, then bounce the tracks through the BFD stereo plugin. (*NOTE - I write the drums track by track meaning, bass has its own, snare has its own, etc, it makes EQing and volume work MUCH MUCH EASIER!).
When I have a snare track for example, I write it using general midi, then the BFD DXI plugin in cakewalk, create a seperate midi track for the BFD SNARE, and then load the snare into BFD and bounce the track THROUGH the plugin to get the beautiful snare which ends up being bounced to an audio track... it can be a pain in the ass, but the results cannot be matched! You would not know the difference between the output and a real drummer, believe me!
