Signal Flow
  • Thread starter Thread starter ohmeohmy
O
ohmeohmy
Can people explain their signal flow through their studio, or high-end entry level (if there is such a thing) studio. I don't care about the exact gear right now just the generic name of it like mix, preamp,mixer... and so on. I know this can get pretty complicated. Does anyone have any good pictures of the flow through a pretty decent studio?
Thanks
I'll assume you mean analog sound sources (vocals, accoustic guitars, etc) In my relatively modest studio
1) Sound source into a mic
2) Into a mic pre - or - channel strip (mic pre -> gate -> compressor -> EQ)
3) From channel strip into A/D converter
4) From converter into computer
5) Out from computer thru D/A converter
6) From D/A converter to mixing board
The mixing board sends the signals several places
1) Though the channel inserts - to and from various compressors (mostly for lead vocal, bass gtr, kick drum & snare drum)
2) Through the channel effects send/return - to and from various reverbs, delays, etc.
3) Through the stereo monitor send to a monitor amp, which routes the amplified sound to a speaker selector box, which in turn controls 4 sets of speakers
4) Through the main stereo send to whatever 2 track mixdown deck is needed (DAT, CD, Cassette, etc)
For my mixerless studio:
Record:
mic-->preamp-->A/D converter-->PC
Playback:
PC-->D/A converter-->power amp-->monitors
and
PC-->D/A converter-->headphone amp-->headphones
Mixdown stays in the PC, gets burned to CD.
different way
i am just learning, like you. but i don't use a computer, i use a SIB. so i'll give you my set up.
(vocal)
Large Diaphram Stuido Condensor Mike -->
Mike Pre [Channel Strip] (This is a mike pre-amplifier, that has a built in compressor/limiter, de-esser, and parametric eq) --->
Outboard sound effects processor [reverb unit] (it's best to NOT do it this way, but because i record into a MR-8, i cant treat each track on the way out of the SIB. So i treat it on the way in. The catch is you gotta get it right, or you do the whole track over and over) ---> and over and over and over........
EFX into console ( i know this is an un-necessary step, but it allows 2 thing.. i have a calibration tone in my console to set the proper recording level into the multi track. 2ndly (if thats a word) it allows me to have everything plugged in at the same time and not be swapping cables into the recorder. I have a patch bay and could go around the console, but i like the cal tone....)
Console to Multi track recorder
(GUITAR)
electric (2 ways)
guitar into digitech effects pedal with speaker emulation -->
digitech into console (in stereo) [have the option of compressio/limiting, and eq built into the pedal, other wise insert here] --->
console into multi-track [with option of eq, compression across the track & master out buss in console]
(2nd option)
SM58 infront of amp grille -->
SM58 into console ---->
console to multi-track (same as above)
as a basic rule. you want to record a STRONG (not clipped, especially if digital) and clean signal. Then you can add effects such as reverb/echo, compression, and eq later.
good luck
mic->mixer->direct outs of mixer->effects->adat->remaining channels in mixer
