jkuehlin
Guys with large format pro mixers...do you use your aux sends (as in the horizontal row of knobs on the physical desk) for anything other than monitoring? Or do you pretty much let your DAW handle the time, mod, and verb based effects? If so, what do you have patched to through the aux loops?
I have 16 sends on each channel, and the i/o to support it. Seems like a waste not to use them. I don't need a single one for monitoring because the Aviom units handle everything, and can draw the monitor mix from the foldup matrix on the center section.
And do you guys use your onboard flying fader automation, or do you just write it in the DAW? (I have pretty reliable recall on the System 5B).
If anyone has an SSL 9000j, or Harrison, how do you route to the a 5.1, 7.1, or atmos decoder from the aux send? (or do you not even use them at this point?)
