Transmutant
Hello!
I was annoyed how you can only use this mic for so few things. I could not find pictures of one fully opened so I thought what the hell. You can always buy new if it's destroyed? Right.
The inner circuit was fairly simple. A chain on components was connected parallel to the capsule signal. 15mH choke, 22ohm resistor and two 22uf condensers. This circuit creates a (around) 390Hz dip. Something you would do to the sound in the mix. The thing is, it's not always the frequency that needs to be cut. It all depends on the size of the kick drum and the thickness of the shell. Besides you could use this high SPL mic for other things too. The preset EQ just makes it harder to use.
Disconnect any component from the chain and the preset EQ is bypassed. I drilled/carved/filed a hole in the back and installed a switch between the choke and R1 so you I can do A/B comparison. The resistor was the easiest to work with because the legs can be lifted up.
The leads from the capsule were really thin and long. I decided to shorten those too while I was at it.
I created an album with pics. Go check it out.
