A couple of thing might be worth mentioning
1. Pro Tools is THE standard professional DAW, period. If you wonder why....... stop wondering, it is the #1 for good reasons, unless of cause the vast majority of engineers around the world are clueless, earless morons.
2. The whole thing of "a load of major name engineers are switching to Nuendo" ------ For that please read: "a load of major name engineers were given complete Nuendo systems for free in return for the use of their name". I'm not saying its a bad system, but know a couple of them with Nuendo systems at home, working on Pro Tools in the studio. Don't always believe the hype.
3. You get what you pay for. For the money, systems like the Mbox for under 500 bucks, the 001, the 002, are extremely good value for money compared to other systems, with the major advantage being that they are all-in-one systems, so you don't have to struggle with non-compettable soundcards and the like.
4. Also under the you get what you pay for banner - you can get very good results with something like an Mbox for instance, but don't compare it to a top 2" machine or a top digital system. An Mbox has 2 A/D and 2 D/A converters as well as 2 pre's. All for under 500 bucks. If I would take the cost of 2 of our A/D's, D/A's and pre's here, multiply that figure by at least 10. Then add clocks and sample rate converters, etc. etc.
5. As far as all the "I have compared a to b to c and" stuff goes, it is very difficult if not impossible to do a fair comparison. Things improve all the time, just look at for instance Pro Tools Mix with a 888/24 I/O and compare it to a Pro Tools HD with a 192 I/O. Compare the first to a Nuendo system and it will sound bad using its generic components. Compare the second to Nuendo and it will sound much better ......... and then it still all depends on all the components that are hanging on the systems.
In conclusion, I think one of the key reasons why people always seem to bash Pro Tools is because its human nature to try and pull down a market leader. Also, the shear number of users means there will be more of them with something to say, be it good or bad. As far as I'm concerned - and having used most of the "pro" DAW systems in a professional capacity, Pro Tools is the most user friendly and the most time effective system. But even a large Pro Tools system will have its shortcomings, like the much discussed "summing problems" of high track count sessions. Is this a Pro Tools exclusive problem? Hell no!! The problem exists in all DAW's, as summing normally takes place through one single chip. It a problem that can be solved. It is the reason many "artists with a budget" will record and mix in Pro Tools, and then go to a studio with a large frame analogue console to route / sum their tracks (and in the vast majority of cases fuck their sound up by using crap converters). We solve the "problem by using an all digital summing system, whith a number of cards, each one fitted with 4 powerful sarks capable of routing 32 channels. This system solves the routing problem without introducing any loss or digital artifacts, in fact it sound much better than routing a high track count through any large frame analogue consoles. The reason why its not part of any, even the most expensive DAW's on the market? The routing system costs more than any DAW on the market, its that simple.
If I carry on I'll become like Sonus and start writing mini books!!
