joro
The Pie Guy
you fellas can have first crack......
For Sale
Two (2) EV SX 250 powered PA/monitors
Not quite 3 years old – no mechanical issues
Some minor cosmetic blems – stage wear mostly
The Electro-Voice Sx250's multi-angle enclosure makes it one of the most versatile speakers in EV's Sx series. Because of it's enclosure design, the Sx250 is perfectly suited to be either a floor monitor or a hung/pole-mounted PA system. The Sx250 combines Ring-Mode Decoupling (RMD) and a horn to produce pure, clean vocals and detailed mids over a wide coverage pattern and varying SPL's. It's enclosure is made of 18mm plywood that is finished in Futura. This polyurethane finish is naturally resistant to damage and weather conditions, and can be easily painted. The Sx250's components are protected from damage by an 16-gauge steel grille with cloth backing for a smooth, professional look. With high, continuous power capabilities, housed in a ruggedly compact and portable design, the Sx250 is ideal for multiple applications.
Lowest price new is $600 each
Selling the pair for $900 ($450 each) plus shipping
I paid $150 each for the stands...they are EV stands
sell the pair for $200 plus shipping
For Sale
Two (2) KRK V4 active monitors
Video Shielding: Standard Drivers: HF 1" Soft Dome Tweeter
LF 4" Kevlar Woofer Input: XLR & 1/4" TRS Combo
10K Ohm Balanced
Pin 1 + Sleeve = Ground
Pin 2 + Tip = High
Pin 3 + Ring = Low Amplification: 90 watt Bi-amp with 12dB/octave Dimensions: 9 1/2" x 6 1/2" x 7 3/4" (23.6 x 15.9 x 19.7 cm) Shipping Weight: 11 lbs (5 Kg)
Paid $350 each
Sell for $200 each plus shipping
For Sale
Two (2) Sennheiser MD421 microphones
Excellent cabinet/instrument microphones
• Glass composite housing and hardened stainless steel basket - rugged and durable
• Five position bass roll-off switch-compensates for proximity effect
• Frequency response 30Hz-17kHz
• Effective feedback rejection
• Clear sound reproduction
• Easy handling due to pronounced directivity
• Acoustic components enclosed in inner chassis-reduced sensitivity to dust and humidity
• Internal bass tubes-accurate low end response
• Handles exceptionally high sound pressure
Retail new for $510 each
Sell for $350 each plus shipping
Comes with stand clips and hard shell/molded foam lined cases
Pictures of all items provided upon request
Please contact me via PM
There will probably be more items to come
For Sale
For Sale
10K Ohm Balanced
Pin 2 + Tip = High
Paid $350 each
For Sale
