zed32
Re-Attached Member
Dogman said:I haven't a clue what I'm doing...but if you ask 5 drummers how they set their drums up...you get 25 answers....![]()
24 of those answers would be "what?
zed32 said:OK here's some pics i took today now that i'm at home. the kit is up against the back wall so i can't really get a good driver's seat pic, so i kinda had to take it at an angle.
i guess i like em kinda flat. which is why i like having the smaller shells, it allows me to keep them low and flat at the same time so it's good for my short arms.
ez_willis said:Do you sit pretty high up above the kit?
Dogman said:After seeing Greg's pics, I did drop my throne a bit, and found I wasn't reaching for the kick as much, and used it a bit more. I had to move the hat, and snare to accomodate, but I also was playing better right away...just fit me better.
I haven't even begun to focus on technique. I got good enough to track the drum parts with a consistant meter and hitting the drums properly, and sort of got content with that.zed32 said:one more thing i'll add is that even though my thighs aren't parallel to the floor, my shins are still pointing straight up and down because i play heel-up and with my foot a bit more than halfway back on the kick pedal. if i put my foot all the way up on the pedal, then i'd be reaching, but i actually prefer the feel of having my foot farther back. i dunno if thats good or not, but all that stuff plays into how i sit (up and away) and how my drums are set up.
I played barefoot one night, and the beater bruised the top of my foot....guess I should adjust that sucker...ez_willis said:I play barefoot and pretty much use the tip of my toes to give it all the power I can muster.
True, but your formula doesn't include variances for body types. I have long leg/short body syndrome,, so my kick drum has to be about 3' away from me.Blue Groove said:Just because it seems comfortable now doesn't mean that it isn't doing long term damage. Ergonomic setup will even make great drummers better. It's all about the mechanics of the human body. Machines will work wrong, but something will break. Efficiancy is lost due to extra movement.
Wouldn't setting it up so it's comfortable be the very definition of "ergonomic setup"? There's no extra movement if things are easily within reach and at a comfortable setting.Blue Groove said:Just because it seems comfortable now doesn't mean that it isn't doing long term damage. Ergonomic setup will even make great drummers better. It's all about the mechanics of the human body. Machines will work wrong, but something will break. Efficiancy is lost due to extra movement.
