N
NYMorningstar
Recording Modus Operandi
This choir is actually up on the altar in a small/medium size church. So far they're using 2 sound systems. One system is using 5 miniature condensors hanging from the ceiling(in between the floor mics) and on the lecterns using an EV board. The other system is 6 Shure 58's going through a mackie pa head.
There are 4 speakers, 2 mounted on the front wall using the EV and 2 on poles in the back facing the front using the mackie.
When I first got involved with this there was major floor noise and feedback and some mics not working. I looked at the mackie head and saw the graphic equalizer set up looking real pretty, with an almost perfect bell curve, and the faders looked as even as witches teeth. The parametric equalizers on each channel were everywhere, almost like a kid was using them to make an etch-a-sketch with the effects feeds(set to small hall
) about the same. The EV board looked pretty much the same.
I was real short on time so I zeroed out the EQ across the board, set the channel pres halfway, and put all the channel faders at zero db and turned off the effects. I raised the mains until I got feedback and then backed them off a little. I had no way to test this so that is how they used it Sunday morning.
Aside from the fact that for the first ten minutes no one turned on power for the EV system, the service sounded pretty darn good. No feedback, no floor noise and you could hear everyone in the choir, including the men
The only problem was the back of the church was too loud.
The speakers in the back were basically being used as monitors for the choir and were way too far away for that. This week I am putting a couple wedges in front of the altar facing the choir and moving the speakers in the back of the church up to about midway and turning them around to face the back. This way I can turn down the volume on the back speakers and the choir will still be able to hear themselves.
Questions:
1. Which sound system should I put the wedges on, the EV or the mackie or both? Should I use one system to just monitor? If I record this it will be on the EV system.
2. Should I move the back speakers up halfway or all the way to the front?
3. Is there a better way to set the gain structure? Should I leave the EQ alone. The system sounded transparent without it and real good. No effects?
4. The mackie has an onboard compressor, leave it off?
) about the same. The EV board looked pretty much the same. I was real short on time so I zeroed out the EQ across the board, set the channel pres halfway, and put all the channel faders at zero db and turned off the effects. I raised the mains until I got feedback and then backed them off a little. I had no way to test this so that is how they used it Sunday morning.
The only problem was the back of the church was too loud.The speakers in the back were basically being used as monitors for the choir and were way too far away for that. This week I am putting a couple wedges in front of the altar facing the choir and moving the speakers in the back of the church up to about midway and turning them around to face the back. This way I can turn down the volume on the back speakers and the choir will still be able to hear themselves.
Questions:
