daav said:
Looking for some opinions about this, essentially as a newbie.
What exactly does this entail usually, is "set up" and adjusting intonation the same thing?
Set up on a Les Paul typically involves the following:
- Remove the strings
- clean electronics
- clean/oil fingerboard
- clean polish guitar
- adjust the nut slot height (careful, you could easily fuck this up, and if you don't have the right tools or haven't done it a few thousand times, you will)
- put on new strings
- adjust neck bow (careful, you could break the truss rod)
- finish adjusting the nut, if nessicary (same caution as above)
- adjust bridge height (too low, it buzzes, too high and it sucks to play)
- adjust intonation with a Strobe tuner (if you don't have a strobe, you can't get it right. Period. Nothing else is as acurate)
- Adjust pickup height
All in all, about $500 worth of tools, if you go with a Virtual Strobe, more like $1500 if you go with an analog Strobe. Plus the room to store them, and of course then you need to learn to use them. Many of the skills involved are NOT simple, and it takes a lot of experience to get it right.
daav said:
How often do you get your instuments set up by a "pro"?
THAT'S a loaded question. I mean, everytime I setup my instruments, it is by a pro (me), but then there is that old saying about a coblers children, you know?
daav said:
How much is a good price for such work?
Our hourly shop rate is $70 an hour, and we charge about $75 for a setup. Expect it to take you much longer to do it right. We do it more often.
daav said:
Can anyone who is fairly mechanically adept follow some instuctions and do this themselves? If so is there a guide anywhere that would allow me to DIY my way to being a bit better of a guitar tech?
Some of it, yes; some of it, no. I would never recomend that you adjust your nut, as you don't have either the tools or the experience. Same with intonation, if you don't have a Strobe. The truss rod is a more difficult question, as the likelyhood of a problem is fairly slim, but if something does get fucked up, you are in for a VERY expensive repair. Also, I don't have any way of telling you how to adjust it, as I have done enough that I just measure it by eye. Fret at the first fret and the fret where the neck starts getting fatter as it goes into the body. Around the middle of that length of string, you should have about a playing cards thickness between the top of the fret, and the bottom of the string. Adjusting the saddle height is no big deal, if you have the tools. Just make sure not to strip out the allens on a strat-style bridge, as they are a pain to replace (sometimes).
daav said:
I'm pretty sure the intonation on my LP studio (early nineties) is way out, but i am inherently more DIY-oriented than pay-a-pro oriented. How do i teach myself to fish here? I also have an old Japanese Strat that I could use as a test if there is danger of f'ing the thing up more than it is now.
At least the first time, get it done by a professional. You will be much happier with the results.
Light
"Cowards can never be moral."
M.K. Gandhi
