A
Alan F Brookes
Serial Copy Management System, was created to prevent people copying minidisks. If you record your own live music onto minidisc, then copy it onto another minidisc, it will contain information that it's a copy. If you try to make copies of the copy your recorder won't let you. I record a lot of my own music using a Yamaha MD8, then I usually mix down onto CD-RW. I'm thinking of mixing down onto another minidisc, but will I run into problems with SCMS? Also, if I make backup copies of my work by copying from one MD8 onto another MD8, will I have problems if I mix down the backup? Since Sony designed the Minidisc with these restrictions, but the MD8 uses Data MD disks, I'm wondering if this is still a problem.
Being brought up on reel-to-reel I'm not used to these sort of problems !
