Screaming <--> singing
  • Thread starter Thread starter Verraes
V
Verraes
Recently I've been recording a song. The lead vocal exist out of singing and screaming. Should I record these on separated tracks and should I also mix them differently? If so, what are the differences I should deal with?
Thanks a lot
Steven
Most bands I record (including my own) have singers who do this.
If the parts are DEFINED (like nothing inbetween...clearly there are singing parts, and screaming parts), then I say record it seperately. get the right levels for each, put em on seperate tracks. usually i compress screaming a bit more than normal vox - to really bring out the gut of the screams.
if it is really spiratic and random, I just set the level low enough for the loudest parts (screams usually..ha)...then let the vocalist do his thing. Then, when i mix - i try to cut up the parts, so anything that is clearly singing, I can just copy to another track, and leave anything that is screaming or close to it on a track. then, i still have the ability to mix/compress it differently if needed.
you just gotta be careful though
oh yeah, and I'm using a computer - so i have that ability easily...with 4 tracks you may not be so lucky.
by far the best thing to do is to record them on seperate tracks. i find that screams almost always benefit from a decent amount of EQ that would just make a regular vocal track sound ridiculous. not to mention no matter how much scar tissue the singer has, screaming while singing beats up the voice.
my take would definately be to take separate tracks and experiment with the levels/effects/etc. you may also want to rather lightly pan them, or if you're looking for a more chaotic in-your-face listen, pan them hard when both voices are going on.
