R
Rod Gervais
I was trying explain to him what you wrote about using a puddy pad around the box, and he wasn't understanding.
UG,
A putty pad is just that - it's a flat pad made of fire proof putty - it can be oicked up at any electrical supply warehouse - it doesn't stuff the box - it wraps around the back of the box - and around the wires entering the box.
Picture your drywall mass - and then look at your box - it has little mass at all - the putty makes up fo rthe loss of mass - and is good to about a weighted 40 dB of isolation.
Now - I am not going to mention this again after this last time.
The walls (and ceiling) you are building is what is typical for a standard office - nothing special - not very sound isolating - and something that you will hear the radio in the next room.
You seem to thing that concrete is a great isolator - and (for the purpose of music) it isn't........
I suppose the best thing would be for you to do your single layer (but make it all 5/8" - the 1/2" is useless) and then set up a pa system and play some music through it at the same levels that your band will be playing at - then check around to see how well isolated everything is.
Do this before you paint everything out and do all you trims and stuff - because then when you want to add another layer it won't be a killer.
And - before you tape your corners and to the floor - make certain you caulk them using backer rod along with the caulk.
That is your maximum isolation - because wherever air can go - sound goes.
A 16" thick crack along the edge of a wall 10' long is the same as a a 7 1/2" square hole right through the wall - that's 3 x 2.5 just sitting wide open -
The caulks are important - very important.
Rod
