Say it ain't so...... BR-8 Question (Bouncing)
  • Thread starter Thread starter Rudd
R
Rudd
I am trying to bounce tracks on the BR-8. So I recorded my drums on tracks 1 and 2. I then recorded two separate guitar tracks in stereo on tracks 3/4 and 5/6. I then tried to bounce 3/4 and 5/6 to tracks 7/8. Well, it worked fine EXCEPT I lost tracks 1/2 with the drums...... What happened? I only wanted to bounce the guitar tracks to blend them but the BR-8 wanted to bounce tracks 1/2 as well. When I was done bouncing it erased tracks 1/2!!!! Help! Isn't there a way to dictate exactly which tracks I want to bounce? I couldn't find it anywhere in the manual.
This is a big problem and an even bigger bummer if it's true that I can't bounce only what I want.
Am I missing something????
lost audio ??
I did this the first time I bounced...... Look in the v-tracks. Tracks 1&2 should be there yet. Good luck.
Hmmmmmmmmm.......... I checked it out but the V tracks were empty..........
As soon as I switched the mode from "bounce" It emptied all the tracks except for the two tracks I had bounced to.
I'm still perplexed.......... this seems like such a basic function that I find it hard to believe you can't safeguard a track. This is a MAJOR downfall of the BR-8 if I can't figure this one out........
sounds like a downer
I too had the experience of losing work after a bounce. In frustration I consulted with Roland/Boss techs via telephone, yuh know, to gain some insight. (?)
This is when I was informed that, when bouncing, info on all previously recorded tracks (that is,....other than the destination track for the bounce) will be shifted to the next level in v-tracks for storage until erased. Which has to be done manually through utilities. (the LCD display is not too well designed for relating v-track info, it can be confusing, I'd like to see a change there with software improvements using a downloadable flash to the eprom)
Again, I too thought this feature sucked.... Until, I found the advantages of multilayering "doubling" to fatten up or support the bounce. Or if the mix on the bounce turned into crap after review ( I usually had troubles of losing amplitude with a bounce, I am getting better as of late) just erase the bounce, optimize the song, and remix for another bounce. Digital can be cool.
The BR-8 does have somewhat of a learning curve to get some tasks done. I want to try some MIDI syncing with drum machines or software based sequencers. Never did it before.....
Good luck again !!!.... Keep on jamming,
Hugh
Thanks!
Well, I've since moved on to another project (got several going at the same time, of course!) I'm going to go back and investigate this again. I FORGOT about the "undo" command I could have done on the bounce! *smacks forehead*. That would have saved me some time. I'll check into this further....
MIDI is where I'm headed next. First I'm going to investigate slaving my DR-5. I think this will be very useful since I often discover I want to make subtle changes to the drums during the final mix.
All in an effort to create the best sound possible out of this little device! that's a great idea about being able to download upgrades. I guesss I should be sending feedback to BOSS as well. This is a great little unit but it could stand a couple of little adjustments........
thanks,
Rudd
