RP50 Question
  • Thread starter Thread starter akaMrC
A
akaMrC
For those of you who have one...do you set the volume at one level for all the patches or vary them? If varied, is there some tip on what is best for different types of patches? The problem I have is that when I switch from one patch to another the volume goes up or down depending the patch. So I might be playing at a reasonable level, then switch and almost blow my ears out, or the patch is too low. Any suggestions?
I used the RP 100 for a while and what worked for me was to find the patches I liked then saved them to the user locations. I would then taper the volumes to rhythm and lead patches and have them next to each other, a pedal press away. Only major problem I had was that the green LED readout will disappear if you play an outside gig in bright daylight..I couldn't tell which was which!
You need to adjust the amp level (under the amp model), for each patch so that they match. RTFM. :D
