B
Burden of Proof
Hey all,
I've just made the investment in a Yamaha MG 16/4 (yay!) and the next step is some decent powered monitors since I don't have an amp. I'm currently taking the 'recording' out (rca's) into my Audiophile 24/96 and using my computer speakers (2.1 proprietary system shipped with the Dell) as monitors.
I'm going to eventually upgrade the system with a delta 1010 or something else to allow the 8 insert sends from the Yamaha to go into the system individually, which leads to question #1: What cables do I need for this? Just 8 unbalanced 1/4" phone to RCA connectors, or is there a snazzier way of doing this? Plus, isn't it bad news to use unbalanced connectors connecting so close to my computer and sound card? Alternately, for now, is there a better way to get output from the mixer to the soundcard than through the pre-master-fade recording output (I tried connecting the main output to the card, but that's at +4db and I think the Audiophile input is line level - everything was way too loud)?
Next, once I have monitors to connect the output of the mixer to, what is the preferred method for bringing the sound back out from the computer to the mixer? I figure I've got rca in's on both 13/14 and 15/16 to plug some output through - but then won't I be getting double signal from the originating channel and the computer output? I've got group sends, so would this be an issue of switching so I'm only hearing the group output on the 13/14 and 15/16 pairs when monitoring and using the regular stereo output for initial levelling (or reverse)?
I've seen that lots of folks use this type of setup, but I'm not sure how exactly it's done. There's a diagram in my mixer handbook, but the connections just didn't seem to work out that way with my sound card's connectivity. Also, when 'tapping' the inserts on the mixer, is there an advantage to using a certain type of cable, or it's just the old 'tip instead of ring' trick? And does balanced/unbalanced make a difference on those connections?
I'm sure this has been addressed before, so if there's a thread you can point me to somewhere that would be great.
-The Burden-
-The Burden-
