Michael Jones
I had read in a book, sometime ago, that there is an ideal W:L:H ratio of dimensions for both a tracking room, and a control room.
Does anyone know what these are?
)Roker1 said:so John, what would be the main reson(s) for you not liking the rectangular shapes....?? thanks
)Roker1 said:bethoven...in the jungle I live in rectangle and square are two different shapes...don't know about yours :0)
I thought that a square has 4 sides of the same length and rectangle has 4 sides as well...but here is the catch...usually two are longer (they share the same length) and the other two are shorter (and they share the same length)....
Also, a lot of people here have no way in hell of building anything substantial until they move out of their parents home/rented apartment/buddy's place, and for them it helps to know what to expect from a particular (available) space. If they know they will have a problem with lower freq's and need absorption, they can learn that thin treatments won't work and either buy or build a portable, thicker solution that will actually work.
Yeah, those numbers look familiar. And I believe John's was 5mX6mX2.3m for a MINIMUM sized control room. Is that right? Converting that to a ratio I'd end up with 2.2wX2.6LX1.0H. Which seems to be pretty consistant with your findings.Michael, to answer your initial question, one of the several popular room ratios alluded to in several of Everest's books is 1:1.6:2.33
