Tadpui
Oh you guys will love this one...
The damn end-cap of the truss rod just unscrewed right off the truss rod! Now what?
I don't know what to expect from their customer service dept, although I've heard good things from other people. But come on, why would you possibly include a piece that will readily unscrew from a truss rod? That's like having the head of a wood screw unscrew from the screw itself! Pointless!
Does anybody know if this is a common design element of cheapo guitars and basses, or is their design team just high?
Tadpui said:I adjusted the truss rod on my SX 5-string bass and ended up putting more bow in the neck that I liked. So I went to straighten the neck by loosening the truss rod and ran into a surprising discovery. The hex head at the end of the truss rod is SCREWED on. This means that as long as you are tightening the truss rod, you're fine. But when you go to loosen the truss rod, all you end up doing is unscrewing the head of the truss rod, not turning the truss rod itself. I would strongly suggest that you rethink this method of truss rod assembly because it makes it impossible to turn the truss rod counterclockwise. As you know, this is not good at all.
So what do you suggest I do to loosen my truss rod?
