JimmyS1969
MOODerator
Any recommendations for a reverb that I can use ITB during tracking with X-tra minimal latency. I don't care if it sounds like ass. I just need something for the '80's guys who demand it.
I use a TC powercore card
I really like TC reverbs and always get good comments on the space I make in mixes..theyre pretty cheap for the express ones, around $100 on fleabay..but they are long PCI cards..your PC has to be able to take them..on the bonus side theres quite a few plug ins with it..the 1176 comp is definitely usable
CPU is negligible with DSP cards
That is of course unless you're using something with inbuilt latency compensation like pro tools 9. (which will then make everything else latent too?)
What DAW do you run?
Does that card interact with your DAW??? I don't understand... What in Dave's name is going on here?
yup, it has vst's that use the dsp power of the card rather than CPU power...its the same with UAD cards, which I also use...there is some CPU usage but its a fraction of what a native vst uses
Can you only use the VSTs made for that specific card? you just drop them in your VST folder like any other VST and they run mainly on the card instead of the CPU - so you couldn't just relegate your existing plug-in VSTs to use the new card right?
