F
fendorst
I use Reaper running on Windows XP. Reaper includes VST plugins, including reverb. The question isn't about Reaper's reverb plugin, though, rather about any VST reverb plugin.
A VST reverb plugin is a digital approximation of real analog reverb. Basically digital distortion, but users consider it pleasing distortion. The better the plugin, the more pleasing.
I also have an outboard Alessis Nanoverb reverb unit. It too creates digital reverb.
I know if I use the Nanoverb when tracking I can't change the sound later. Using a VST plugin I can tweak the reverb after the fact. But I'm not asking about usability issues.
I'd like to know which is considered preferable? Am I better off using the Nanoverb so as not to tax my CPU resources? Is it likely that the digital approximation in the Nanoverb is "better" than the digital approximation in the Reaper reverb plugin because the Nanoverb was optimized to do only one thing well? Or since the Reaper plugin is so much newer, is it likely to be better than a 10-year-old Nanoverb? Are they both garbage? Should I just listen to the difference and use the one that sounds good to me?
Thanks in advance for your thoughts/opinions.
