darnold said:
Ive had a problem recording the snare drum on a set for quite some time. I can get the rest of the set to sound just fine but the snare always has some kind of tinny sound (on a SM-57). whats the best way to fix this?? ive tried mic placements which helped a little. i turned the threshold up on the compressor (which helped a little but that really squoze the sound). any help?
Okay tell me the following:
1. What make and model of drum.
2. Heads
3. Tensioning
4. Outboard gear (gate, compression, EQ, etc.)
I've found that most drummers tune their snare WAY too tight. If you want a higher pitch-get a smaller drum!
I use two snares, and both are "free-floating" Brass models by Pearl.
I use a medium tension on both. 1 is 8" deep, and the other is 5" deep. If I want a higher pitch, I switch to the 5" drum.
The snare's batter head should NOT feel like a desk! there should be some "give" in it.
I have seen drummers crank their heads so tight(and they almost NEVER tune the drum evenly) to the point that They have warped a $40 dollar Cast Rim, and once it's warped-that's it-it will never tune properly.
1. Loosen the Snare Strainer.
2. Set it into OFF mode.
3. Tune the drum to where it sounds good by itself, and with the rest of the kit.
flip the snare strainer to the on position(Raise the snare to the snare bed.
4. Slowly increase the tension of the snares while LIGHTLY tapping on the top head with a stick.
5.Stop after a few turns from snare contact(Just make a couple of turns from the point that the snares begin to buzz when you hit the drum).
Mic the drum from the top-and Aim it towards the Drummer, now tap on the drum while listening through headphones, and move the mic around while you are tapping the drum.
Then you can E.Q....
If I do not have an outboard E.Q., and only have access toa 3band mid shift EQ(like on a mackie 1604)
I usually wind up pulling somewhere between 350hz.-800hz. range While recording. Then I will boost in the 100-200 range on playback.
Compression? I compress the heck out of the drum.
I use a high Ratio, I barely bring down my threshold. essentially using it like a limiter. Also, in some situations, I'll drive the Mic gain really hard for a bit of overdrive, and use the Compressors output to actually control the volume going to tape.
Also, you can patch a distortion unit inline if your recording in Digital to simulate tape distortion. (After all-a snare is really nothing more than white noise, so whats a little more distortion! think about it)
I do sometimes use a PEQ (an Aphex "Tubessence" 4 band Parametric) to pull where the snare is ringing-I prefer this to muffling the drum.
Tim
