H
Han
leddy said:That is a fact. Getting the ride cymbal out of the bass mic is a challenge. Choice of ride cymbal & sticks makes a big difference. The best mic I've used so far for getting a good bass sound with enough rejection is the Beyer M88. The bass and ride cymbal have to sit well together or the whole mix will be a struggle, IMO.
Leddy, as you know I've done some experimenting with upright: http://www.homerecording.com/bbs/showthread.php?p=1823977#post1823977
You gave me kudos, thanks for that. I've been using the SP B1 in the upright's bridge and that does work quite well.
In recording jazz the main problem is the upright bass, it's a big instrument that should be recorded from some distance in order to record the whole instrument. So you might put it in the vocal booth, but the band doesn't like that nor does the bassplayer. So you decide to put them all together in one room. And indeed the Beyer M88 is a nice mic for the job, but it's a front adressed microfone that points up when put with some foam into the bridge.
So the best you can do is putting a side adressed mic into the bridge and when you're on a budget, the SP B1 is near perfect, use a high pass filter to avoid boomyness because the proximity will be huge, but the little amount of bleed will make your day. Point the mic a little to the F-hole on the G string side.
The other problem with jazz is the trumpet, a ribbon can do wonderful things here, but a Sennheiser MD441 will make you very happy as well.
A MD421 on T-bone will do the job quite good and a neutral LDC will do quite well on reeds.
I hope this will help you.
Peace, Han
