C
celerond
Hi,
Just want to get started doing some recording..
I have a Toshiba Equium A60 155, 2.8gh 256ram laptop, windows xp and I was gonna add some more ram and get Fast Track USB which has the spec below...
My basic question is, will this work ok on my laptop???
Thanks
Fast Track USB
Full Features
easy to connect and use
professional 24-bit/48kHz sound
dynamic microphone input (XLR) with gain control and signal LEDs
switchable instrument/line input (1/4”)
stereo headphone output (1/8”)
stereo output jacks (RCA)
level control for headphones and main outputs
USB bus-powered
compatible with GarageBand and most other music software
USB class-compliant (OS X 10.3.5 and higher) for plug-and-play operation
direct hardware monitoring for synchronized overdubs
mono switch sends input signal equally to left and right channels
includes GT Player Express software:
• professional effects
• guitar amp and stomp box modeling
• plays standard audio files with variable speed playback
• standalone operation, ReWire or VST plug-in
Specifications
general
sample rates 44.1kHz and 48kHz
dimensions 5.5" x 4.25" x 1.75' (14 x 10.8 x 4.5 cm)
weight .45 lbs (.2 kg)
Microphone Input
max input -2.2dBu (0.6 Vrms), min. gain
signal to noise ratio -100dB @ 48kHz (A-weighted), min. gain
dynamic range 100dB @ 48kHz (A-weighted), min. gain
THD + N 0.0053%, 1kHz, -1dBFS @ 48kHz, min. gain
frequency response +0.08 / -0.12dB, 22Hz to 22kHz @ 48kHz, min. gain
available gain 45dB
input impedance 1M Ohms
input (guitar setting)
max input +3.2dBV (1.5 Vrms)
signal to noise ratio -97dB @ 48kHz (A-weighted)
dynamic range 97dB @ 48kHz (A-weighted)
THD + N 0.0049%, 1kHz, -1dBFS @ 48kHz
frequency response +0.00 / -0.45dB, 22Hz to 22kHz @ 48kHz
input impedance 500K Ohms
input (line setting)
max input +2.3dBV (1.3 Vrms)
signal to noise ratio -98dB @ 48kHz (A-weighted)
dynamic range 98dB @ 48kHz (A-weighted)
THD + N 0.0045%, 1kHz, -1dBFS @ 48kHz
frequency response +0.01 / -0.35dB, 22Hz to 22kHz @ 48kHz
input impedance 20K Ohms (bal.), 10K Ohms (unbal.)
line outputs
max output +2dBV (1.2 Vrms)
signal to noise ratio -105dB @ 48kHz (A-weighted)
dynamic range 105dB @ 48kHz (A-weighted)
THD + N 0.0039%, 1kHz, -1dBFS @ 48kHz
frequency response +0.03 / -0.15dB, 22Hz to 22kHz @ 48kHz
crosstalk -100dB, 1kHz, channel-to-channel
output impedance 240 Ohms
headphone outputs
max output (@ 32-ohms) -2 dBV (0.8 Vrms)
signal to noise ratio -102dB @ 48kHz (A-weighted)
dynamic range 102dB @ 48kHz (A-weighted)
THD + N 0.0395%, 1kHz, -1dBFS @ 48kHz
frequency response +0.05 / -0.20dB, 22Hz to 22kHz @ 48kHz
crosstalk -80dB, 1kHz, channel-to-channel
output impedance Less than 1 Ohm
headphone impedance 32 to 600 Ohms recommended
Compatibility
ASIO 2
WDM
Kernel Streaming
Mac OS X Core Audio
Min System Requirements
Windows XP (SP1 or higher)*
Pentium II 350 w/ 64MB RAM
* Home and Professional Edition only. Windows Media Center Edition is not currently supported.
Thanks
Fast Track USB
Full Features
USB bus-powered
Specifications
general
Microphone Input
available gain 45dB
line outputs
headphone outputs
Compatibility
ASIO 2
WDM
Kernel Streaming
Mac OS X Core Audio
