Okay I found this
Connecting to Audio Equipment
You can play the 01 through your home stereo system. In most cases, you only need to use 1/L (L = left channel) and 2/R (R = right channel). Connect these outputs to a spare pair of inputs on your stereo. Pretty much any input will work except those designated "phono" (which have special filters for turntables or record players). Inputs labeled "AUX", "TAPE IN", or "DISC IN" should work fine.
The 01 output jacks take "quarter-inch mono" plugs. Most stereos have "phono" jacks, often called "RCA" jacks. You probably have a cable with two phono plugs on each end - one red, the other white or black. Get a couple "phono-to-quarter-inch male" adapters, and attach them to one end of the cable.
As a rule, always plug red connectors into the right channel. This is only to help you remember which color goes where at the other end. The "r" in "red" reminds you of the "r" in "right". (If the other cable is bLack, the "L" can remind you of "left".) You will not hurt anything if you don't follow this rule. It just helps avoid mistakes when you're looking at a clump of spaghetti wiring hanging on the back of an audio panel.
So use the quarter-inch mono plugs and plug into any of the NEO inputs,assign that input to a track and arm the track and press record.
