X
Xiaro
Looking to use my setup to both record vocals and use mics for podcast/live streaming ect..
Hardware:
Mackie 1402-vlz3 Mixer
MDX4600 Hardware Compressor
UR22 Audio interface
Computer
Shure SM7b Mic
How its hooked up now: Just trying to get a non noisey/good volume signal to computer.
**the compressor is hooked into channel 1 with a insert cable, during mic level setup all compressor settings are off ect. for that channel.
Right now I have my mic connected into channel 1 using XLR to XLR
Mixer
- All knobs\faders to Unity or off ect..
- Solo and PFL button on for mic channel
- Change gain during normal/loudest talking level I would produce requires a near max gain to get the mackie to show around just under Line level (0db) to around the 5db. OK cool!
Compressor
- Next i go to compressor settings, Im leaving all compressor settings off and only using it for gate currently to cut out background noise picked up from cranking the gain on the mixer. OK cool! Levels on compressor match those coming from mixer during speech.
UR22 AI THE PROBLEM
- Next I run a 2x 1/8 - 1x 1/8th from the MAIN OUTS on the mixer to the input 1 on the UR22
- Hi-z is turned off ect ect..
- Now I need to crank the gain input on channel 1 to 100% to get the signal from the mixer to the UR22 to be the same. This introduces a solid layer of "noise" to the signal which carries over to the actual recording =(
Now! Doing research ive heard you can use the LINE IN on the mackie instead of XLR (which I tried). I have to UP the faders on the mixer, both from the channel and the main fader to match the dB from before.
However this does fix the problem from the UR22 as it doesnt need to use as much gain I guess? However there is still the problem of having all the faders cranked just to get a signal and from everything ive read this just isnt the best option using mics.
Room Noise
Now I know my computer has a ton of noise, and one main issue Ive had is once all the compressor settings where dialed in I would still get the noise from the background in with my recordings when the gate turned off resulting in what sounded like background tinging from my microphone!
So I decided to see how low I could get my room noise, turned off my computer (brought very quite laptop just to use passively to power the ur22, also piled blankes on the laptop and hid it under the desk). Turned ALL lights off and sat still in the dark. STILLLLLLLLLLLLLLLLLLL the same noise WTF timmy, I mean it cuts down about half the signal I need to use on my gate but either rooms emminate noise far greater than I can understand or rooms really do need to be treated that hardcore just to get a signal that isnt full of noise?
I feel like this is mission impossible just to get a half a real signal to a computer, how is it this hard?
Any help in any direction would help! Is it bad equipment, THAT bad of a room, hooked up wrong? All cables are new and bought from a music store for a reliable source.
Thanks a million
- Lost audio user.
Hardware:
Computer
Shure SM7b Mic
Mixer
Compressor
UR22 AI THE PROBLEM
Room Noise
Thanks a million
- Lost audio user.
