witzendoz
Senior Member
You cannot really recommend EQ settings. The required EQ depends on the bass guitar, the strings used, the player, the type of music, the type of song, the list goes on. I can record myself playing on different projects and the EQ is never the same, sometimes I don't need to EQ at all, sometimes it's compressed, compressed a lot, not compressed. To get a good bass sound you need to have a good bass, good strings and a good playing technique, if the original sound is no good it's never going to sound good. Then you need to experiment with the mixing until you learn what works and what doesn't.
Sometimes a bass soloed can sound great but does not work in the mix, and sometimes you will have a great bass sound in the mix but when soloed sounds like rubbish, if the rubbish soloed sound sounds good in the mix then use it.
Re-amping is a good way to fatten the bass sound if you were not able to record the amp during original tracking (due to spill issues), I would still usually try the original DI track mixed in as well.
Cheers
Alan.
Cheers
Alan.
