mshilarious
Banned
maestro04 said:Won't I have to deal with the phasing problem. If so, how do I tackle that on my D.W.S?
No, because you'll be using a spaced pair and observing the 3:1 rule. Edit: if the two mics are hard-panned (which may or may not sound good), it wouldn't matter anyway, but mono compatibility is rarely a bad thing.
Also gtrman's suggestion to put the wedges on stands is very good. I would also consider a low-cut around 250Hz in the wedges to keep the CD out of your recording.
Try to borrow or rent a pair of condensers, ideally small diaphragm, as they typically have more uniform off-axis response, and better rear rejection than large diaphragm mics.
