B
Bigus Dickus
Well, I don't want to get into a lengthy debate about the merits of active crossovers, but suffice it to say that it is my opinion that active crossovers and biamplification does provide for the simplest and cleanest signal chain.
I also don't believe cost is an accurate indicator of quality. While high cost usually indicates a certain level of quality can be expected, low cost doesn't dictate a lower level of quality. I buy components based on performance, not price - hence the Rotel gear in my system instead of Krell or Levinson. If the dbx XO sounds bad, I'll sell it. If it sounds good, it will have a happy home beside Rotel, Marantz, Denon, B&K, Anthem, or whatever other gear I might have.
What preamp I am using is really a non-issue at this point. None on the market provide the level of signal control that I think is necessary, so no upgrade will currently fulfill my requirements. The only difference between my current 5.1 setup and a future upgrade to 7.1 is that the side/rear surrounds will be duplicated instead of discrete channels until I make that upgrade. However, I will still want essentially full range, bi/tri-amplified speakers at each of the seven channels. You can't accomplish that without active crossovers, and I doubt I will be able to purchase a prepro that can do this in the next couple of years.
I am a bit perplexed about your comments concerning "voltage or current dividers." There isn't anything special an amp needs to do or have to be bi-amp capable. You are simply using an amplifier channel to drive a speaker. It's really that simple. Biamplification is more a function of what happens upstream from the amp - i.e., active crossovers.
And about that sub... I don't care what their marketing department claims - if the sub is in an enclosure, which that one certainly is, then by definition it's not an infinite baffle sub.
Anyone else that might still be reading this, I'm still all ears for other suggestions on active crossovers. After reading a bit about John Elliot's DIY designs, I may take a serious look at that route. Building my own crossover networks will give me the performance I demand at the price I desire, but such designs will always be inflexible. I'd have to essentially build another channel if I wanted a difference XO frequency. The main attraction of the dbx/Behringer/Rane units at the moment is their tremendous flexibility ("dialing in" a crossover frequency is very appealing).
And possibly a new foundation.
