H
Healwin
Hey all,
This is my first post so apologies for any errors. I'm having some trouble with reamping a guitar signal for recording and am unsure what the issue is.
I'm going for a distorted guitar sound (for hard rock), so I'm using a Vox ac15 and an overdrive pedal for the distortion (with pro tools as my DAW). when I plug a guitar through the pedal into the amp it sounds just as you'd expect, the pedal is distorting the signal as it should and it sounds great for rock/metal. however, when i send the pre-recorded (DI) signal through the pedal and into the amp, using the reamp box, it sounds completely different, and not distorted at all. all the pedal is doing is boosting the signal and adding a ton of hiss in the background, yet the guitar sounds as clean as can be. it finally started breaking up and distort after using 2 pedals cranked to full, but obviously i couldnt get a very enjoyable tone this way as the signal was WAY too oversaturated.
I'm unsure what the problem is, or how to fix it? it cant be the amp or the pedal because they both sound as they should when playing guitar through them normally. perhaps pro tools is sending the wrong kind of level (speaker or line)?
this is the first time I've ever experimented with a reamping process so its also possible I've set up something wrong. i am a sound prod student and have much to learn, so please keep that in mind. any help would be super appreciated, even if its telling me I'm a dumbass and am doing it wrong lol. thanks!
