C
connloyalist
Hi All,
First post, so please be gentle
Sorry, this is a long one.
This requires a bit of background info.
Not too long ago a long lost recording of the community (wind) band I am a member of turned up. This recording was made in 1988 in the Royal Conservatory in The Hague as a student project and the band was playing very well that day. The student was a former member. I found him and he has given me some details of the way things were setup (I remember being there, but not the details of the setup). He says most likely two B&K microphones in an AB setup behind and above the conductor.
The recording turned up on a 10" reel to reel tape. We suspect it is a copy of the master. I transferred the tape to my computer using an Akai GX-630DB tape deck.
Here is the problem, which I suspect occurred during the recording session. Perhaps an equipment problem?
- The first 8 tracks have too much bass and weak highs.
- On the last 6 tracks the left channel has much better highs. Sounds fine. The right channel however has weak highs similar to the first 8 tracks.
The highs start thinning out after around 3000 Hz. and are down to almost nothing above 6000-8000 Hz. The result is that on the last 6 tracks the drums and especially the cymbals etc., which were in the center, sound like they are on the left.
On the first 8 tracks there isn't that much that can be done except perhaps some gentle EQ reducing the low end and boosting the high end.
On the last 6 tracks I am wondering what I should:
1) Leave it as is and accept the flaws.
2) Same gentle EQ'ing as the first 8 tracks.
3) Strongly boost the highs in the right channel. This helps a bit but isn't ideal of course.
4) Sum to mono and recreate stereo artificially by using mono to stereo reverb.
5) Discard the right channel, use the left channel for both and recreate stereo artificially by using mono to stereo reverb.
Any suggestions?
Regards, C.
Any suggestions?
Regards, C.
