Shadow_7
I have Avenson STO-2 mics and a Korg MR-1000 with Mogami Gold cables. This rig is nice and relatively immune to cell phone interference. The mics seem sensitive to high voltage, but otherwise problemless recording most of the time. I recorded at a football stadium down town within a couple blocks of a radio tower this weekend(San Antonio). And fortunately I brought headphones to monitor, as I was picking up the local radio station. I'm not sure if it was the mics, or the field recorder picking it up. Or just the headphones.
I lowered the mics about 2' and most of the signal went away. I tucked the field recorder under the aluminum bleachers and the rest seemed to go away. This chewed up a bit of time to fine tune, which I had planned on using to take pictures and shoot video. Nothing too critical this time out. But I'd hate to encounter this issue again when it really matters. Obviously different mics would help, but I'm not quite sure why I had to move the position of the field recorder to mitigate the interference.
Any tips for taking this possibility out of my equation?
1) different mics (although I don't think this would have completely fixed the issue in this case).
2) better shielding for the field recorder.
I've been toying with the ideal of putting my camcorder inside the shell of an old studio monitor to protect it from the heat of direct sunlight and possible rain. This would also make it so I could mount the field recorder inside the shell as well. The shell would also shade the LCD so it can be seen in sunlight conditions. Should I line the inside of the shell with a few layers of tin foil to mimic the bleachers in shielding the field recorder from this hazard? Or is that of little consequence. It certainly seems that I need to do something special, but what?
I dont know how my reply appears before your reply?
