frederic
I'm thinking I shouldn't be worried, but I wanted to ask.
Hot water radiators, not steam, have water running through at boiler temperature. Now that my studio is in parallel to the house from a plumbing perspective, I'm getting close to 180 degree water flowing through the cast iron radiators.
The small radiator in the sofa cove is touching the sheet rock I just put up, and I'm curious if this is a problem. To move the radiator, or angle it correctly (its tilted at the wall) I'd have to sweat the pipes to rotate it forward, which is doable, but I'd have to drain the heating system at least partially.
I could also shove a 12 gauge steel sheet behind it
Or, leave the shim.
I'm thinking the sheet rock probably doesn't care, but what about the paper surface, and eventually primer and paint?
What do you guys think? I've been told in the past that its okay to have drapes, clothing, etc, resting on the radiator, but now that I'm in parallel to the rest of the house these suckers get really hot.
Or, leave the shim.I'm thinking the sheet rock probably doesn't care, but what about the paper surface, and eventually primer and paint?
