Not necessarily. I don't know what your full micing situation is (each drum, overheads, room mic), but at a minimum if you are using overheads (I'm assuming you are), you might want to experiment with increasing the overheads in a kit mix and sending the whole kit to a bus and adjusting compression from there to pick up more of the kit AND the room. There are a lot of things you can do. You are definitely not in a situation where "it is what it is." Unless of course you like the sound you are getting. It's really up to you. I like dry drums. I like open kits too. It all depends on the song.
