M
Mike Freze
Hi! I have a few questions concerning "double miking" and separating two or more mics when recording.
I know you can close-mic one and have one further back on miking an amp speaker for a fuller sound, room ambience, etc. You can do this with the same mics (say, 2 dynamic SM57s) or 1 SM57 with a condenser mic as the second mic.
Is there an advantage or disadvantage to either concept I just mentioned?
Can't a person just mic a speaker, duplicate the track, and do things with the duplicated track (like reverb, change in volume, change in panning, etc.) to get a great sound instead?
Finally, if you record two mics on an amp speaker (say, guitar), should you record both mics simultaneously to one track (both inputted at the same time in your audio interface) or should each mic get recorded on two separate tracks (again, simultaneously)?
Thanks! Mike Freze
Thanks! Mike Freze
that the 57'll sound good up close (in any number of usable variations on placement), but by it's design would sound full bodied up close but rolled off and thinner as a far mic, where a condenser ('typically'..) starts flatter and might sound more natural at a distance.
