jedblue
beep beep beep beep beep
In the manual for my Revox PR99, it gives the following instructions for checking and adjusting the recording equalization:
1). Adjust AF generator to 12 kHz, 0VU -20db. Okay, I think I understand that, I check that my tone generator is outputting 12kHz, 0VU -20db using the voltmeter then I input the tone to the recorder (at this time, input calibration, playback calibration, recording level and bias have already been done according to the instructions)
2). Start the machine in record mode. Okay, it's now running with a bulk erased tape on and the volt meter has been attached to the monitor output as instructed.
3). Corresponding to the tape speed, adjust potentiometer EQ SLOW, FAST for an output voltage of 0db to +1db relative to 1kHz. That's the bit I don't understand for an output voltage of 0db to +1db relative to 1kHz. If the tone generator is putting out 12kHz, 0VU, -20db and the voltmeter is connected to the monitor, won't it just be reporting back 0VU, -20db? What's meant by 0db to +1db relative to 1kHz?
Any explainations gratefully accepted.
Geoff
Geoff
