B
BluesPower
To use this feature correctly, do you have to have dolby NR turned on while recording and then also turned on while mixing/playback? Or do you only turn it on for the playback/mixing?
I recorded a song with 8 tracks and haven't kept score on which tracks I used the NR and on which I didn't. I think I used it on a few tracks.
What should I do in this case since you can't specifically pick a single track for noise reduction (only 1-4 and 5-8).
Maybe I'll mix the song both with NR on and off and see which one sounds nicer.
