Pughbert said:
This seems a real stupid question, but it seems to be one of those things that got left out for me. Basically, i know were and when to use DI boxes, (i think!) and make use of them regulary to send signal to my amp, then mic it, and send a DI signal straight to the desk, im also using them on bass, somtimes a.guitar too.
I know they impedance match - but why and what is this exactly? -
i know they'll take my line level to mic level - again - why?
And should i be using one on all line signals e.g keys?
Basically - im happy using one - but if i was asked what its doing exactly im unsure - if somone could help me here it would be great - cheers.
James
Impedance is the AC equivalent of resistance (DC).
If you have an amp and a speaker cabinet, the speakers act as resistors. 4, 8, 16 ohms are common. Sound familiar?
With mic and line level signals, the numbers are much higher, and you can get away with more of a mismatch, but it's important that low impedance signals feed higher impedance gear.
http://www.whirlwindusa.com/tech03.html
The artice above has all kinds of formulas and junk, but there are also some good descriptions.
I don't think that DI's do anything as far as changing levels.
The thing that direct boxes do very well is set up a properly balanced AC signal circuit. It has nothing to do with levels or impedance, but you basically have a twisted pair of conductors running through a cable with an outer shield. The shield is there to pick up surrounding noise from AC units, radio transmitters or whatever. Hopefully this keeps all this junk separate from the twisted pair. The shield is usually connected as a ground at all the equipment you're using, and this can be a problem if there's any noise signal there. A direct box will usually have a ground lift switch to break the sheild circuit, so if there's any buzz in the system, you can lift the ground at the DI and it will stop. Sometimes the equipment you're hooking up to won't connect the sheild anyway, so you can keep the circuit closed at the DI. A lot of times it doesn't make any difference, but the best setting is obviously the one with no buzzing.
The twisted pair inside the cable acts as a noise rejection system as well. If one of the signal wires picks up some noise, it's transferred to the other wire as well. 180 degrees out of phase. The 2 noise signals cancel each other out.
An unbalanced cable has one conductor in the middle, and an outer shield that acts as a shield, and also the second conductor. It will act like an antenna, especially if it's over 20 feet long. With a microphone, the signal is weak, so it will lose its strength over 20 feet. It's pretty common for a guitarist to plug a 20 foot cable into a stomp box, to another 20 foot cable, to the amp. It works, but it isn't always noise free, but a guitar puts out more signal than a mic. Basically, the shorter the better. If you're running unbalanced cables that are only 3 feet long, they should be pretty quiet. The longer you go, the more potential for noise.
AC works very well over long cable runs without signal loss, which is why electricity is not delivered as DC. Very few electric devices will actually use straight AC current, so there's usually a transformer or something involved to convert the AC to DC. The electric companies could deliver DC if they wanted to, but imagine having a power station every 20 feet down the road.
Balanced cables can handle very long cable runs.
sl
