Pulsing Amp Noise
  • Thread starter Thread starter canadiandream12
C
canadiandream12
Ok, I have a Peavey Special 212 and a Peavey Vypyr, both solid state. I run an A B pedal through both to switch between amps because I like to use the 212 for rythem and the vypyr for leads. When the I'm using the the 212 and the vypyr is idle on a clean channel, there is no hum. But when the vypyr is idle on a distortion channel while I'm using the 212 there is a pulsing hum that is coming from the vypyr this is really annoying...any help please?
I could be wrong (and I often am), but I'll guess that the input to the Special is left 'open' when using the Vypyr. You may have to redesign your A/B box with at least a DPDT footswitch. I don't know your A/B box, but if it is just a SPDT with no LED's, use a DPDT and have the other input 'grounded'. Your problem should go away. If you have a DPDT footswitch and some LED indicator switching, use a 3PDT switch. Wait, I may be smart enough to know how a DPDT switch could work, activate LED's, and ground the input to the amp you aren't playing through. Or not.
Monkey Allen
Replies
46
Views
9K
FrankD77
FrankD77
themindwillnotletgo
Replies
38
Views
6K
themindwillnotletgo
themindwillnotletgo
Monkey Allen
Replies
5
Views
2K
D
