J
joswil44
This is one of those moments where I feel really stupid.
It seems like I get the idea of boosting the levels of a signal with a mic preamp.
But what I dont get is how your supposed to set your levels while using it.
I bought a Grace Design Model 101 Mic Preamp.
I also have a Mackie 32 Channel 8 Bus Analog Mixer with decent Mic Pre's.
When I bought my setup, a consultant at an Audio Design place recommended I get one for certain applications.
So I have been trying it for my Audio Technica AT4060 Tube Condesor, and a little experimentation with Direct Bass, Guitars using various Shure mics.
Basically its got the Gain knob that goes from 10db to 60 db and a Trim knob that goes from -10db to 0db.
So heres where I get lost:
Normally I set the Channel Volume Faders at 0. Adjust the Mixer trim knob accordingly and then maybe bring the master volume down a little or whatever to get the right input levels on the meter.
Now if I were to tie in a Mic Preamp, the levels are obviously going to sky rocket.
So now I have to turn down the Trim knob on the mixer and find some sort of balance between the Mic Preamp Gain Knob and the Trim knob on the mixer channel.
When I feel like the sound is decent I leave it there.
The Trim knob on the Preamp seems to add more distortion or color the sound.
Which I use a little of depending on what I am running through it.
So whats the proper way to setup a Preamp?
It seems more like it is just overloading my levels that were perfectly fine before.
What exactly am I looking to do here?
Just get a stronger signal that I end up taming down?
Im just trying to figure out what I need.
I see the bigger studios seem to have loads of Mic Preamps.
Anyone out there that can enlighten me to the use of Mic Preamps?
Thanks!
Thanks!
