Projectmix hardware insert problems
  • Thread starter Thread starter Brunothemad
B
Brunothemad
Hi there, I'm using an M-audio Projectmix board with pro tools M-powered, and have just recently set up 2 returns through two outboard compressors (running from the 3/4 outputs back into the 3/4 trs insert points.) However, the volume of the track, when the hardware inserts are applied, seems to lower about 15db, and whenever I increase the gain on the compressor or the input gain on the board, I begin to hear what sounds like lost bits or digital distortion, which increases as I continue to bring the gain up on either side.
Also, latency is an obvious issue, and I still haven't found a viable way to resolve this without recording onto an axillary track and bumping it.
Any ideas?
Thanks
Check the send level on the firewire software mixer. Sounds like they're set to low. Latency? Yep, bounce it to a new track and align. No way out of that one really.
BeatleFred
Replies
13
Views
7K
sweetbeats
sweetbeats
SpecialTricks
Replies
16
Views
7K
rob aylestone
rob aylestone
J
Replies
95
Views
16K
Snowman999
Snowman999
Replies
2
Views
2K
rob aylestone
rob aylestone
