Superhuman
Shagaholic
I have a number of phantom powered units but currently have to run them through a Mackie HUI to be able to use them - my Delta 1010 (primary soundcard) has no XLR inputs. The problem is everything sounds coloured after it passes through the HUI...
Can anyone suggest a cheap fix to the problem? I have the op[tion of getting a Samson S-Phantom http://www.musiciansbuy.com/SAMSON_S_PHANTOM.html at my local shop, it's the only such unit there.
I mainly use a Radial J48 for DI'ing dry guitar (for reamping through a n X-Amp later) and a Sansamp Bass Driver via Phantom on the HUI, will these units go ok through the S-Phantom?? The S-Phantom says it is perfectly suited to condenser mics, is there a adifference in terms of the signal between a condenser mic and a DI box? It looks like the perfect cheap solution to my untrained eye. Will it do the job
Any help or advice is much appreciated.
