J
JoeyNukes
Whats the difference between the two other than one works with just Mboxes?
As benny pointed out LE has command 8, 003 and control 24 control surfaces, whereas M-Powered only has the ProjectMix I/O and Digitranslator is not an M-Powered option.
I guess it likes the "M" productsM-powered will also work with the Mackie HUI....
I'm very happy I made the switch to M. If you're doing video, you're better off using a video editor anyway like Sony Vegas, or whatever else.
Sony Vegas for audio post? I wouldn't bother.
No, Sony Vegas Pro for video editing.
Why would you think I use Sony Vegas for audio if I am running Pro Tools 7.4?
M-Powered does not do video, at least not well... only quicktime I believe. So if you're going to do video, then LE is your choice.
No one was talking about video? It was pointed out as a difference between LE and M, that's why I brought it up.![]()
well, he wasn't talking about editing video (i'm assuming). Cause you can't do that in LE or M-Powered...or HD
I think he was just pointing out that audio for video is weaker in M-Powered than it is in LE (although his Quicktime statement was confusing)
