T
tzaxo
I was planning on buying a Mackie Onyx mixer and the Eleven Rack.
To use the Mackie mixer I have to use Pro Tools M-Powered, to use the eleven rack, I have to use Pro Tools LE. So I have a problem. I love the mixer and the eleven rack. I don't know what to do?
Could someone give me some ideas on how I can use them both with a certain Pro Tools version or?
I did find this that someone said to where I can use the Mackie mixer and the Eleven Rack with the M-Powered version of Pro Tools, would this actually work, good?
Thanks a lot. +R4H.
Although the Eleven Rack cannot be used as a USB audio interface for Pro Tools M-Powered, it can still be integrated into a Pro Tools M-Powered system as a remote-controlled processing system and guitar preamp. You'll need to connect the Eleven Rack's inputs/outputs to available inputs/outputs on your M-Audio interface; and with a USB connection you can use the Eleven Rack Control window in Pro Tools (8.0.1 and higher) to control Eleven Rack and manage Rigs.
Thanks a lot. +R4H.
