sean.brown
Used for less than a year, bought at guitar center. Still have the original box, paperwork and registration! Like new for you!
$85 shipped
Specs:
The new HP4 from PreSonus answers the need for a headphone distribution amplifier with professional specifications in a small package at an affordable price. The HP4 features four discrete headphone outputs on the front panel each with its own volume potentiometer and 150mW of amplification per channel. The HP4 also features adjustment over control room monitors with a separate volume control, monitor mute switch and mono switch giving you an extremely powerful monitoring solution at an amazingly low price.
Four High Power Headphone Outputs
Ultra loud (150mW per channel)
Ultra quiet operation
Musical Wide Dynamic Range
Control Room Monitor Outputs with Level Control
Mono or Stereo Operation
Monitor Mute Switch
Daisy Chain an Infinite Number of Units
Compact package
Input
TRS Impedance10K Ohms
Panel Controls
Headphone Level 1 to 12
Monitor / Feed Output -80dB to +10dB
Mono Switch Monitor / Feed Mute
Power Supply
Type Linear
Input 16VAC/1000mA
Output
TRS Balanced 51 Ohms Impedance
Performance
THD+Noise (Unweighted) 0.002%
Noise Floor-98dB
Signal To Noise>95dB
Power Supply Rejection>98dB
Power 16 Watts
Physical
Weight 5lbs.
Dimensions5.5 x 5.5 x 1.75
Mounting Max Rack and Universal Rack Tray
Chassis Steel
Panel Brushed Aluminum
Sides Cast Aluminum
$85 shipped
Specs:
Monitor Mute Switch
Compact package
Input
Panel Controls
Power Supply
Type Linear
Input 16VAC/1000mA
Output
Performance
Noise Floor-98dB
Power 16 Watts
Physical
Weight 5lbs.
Chassis Steel
Sides Cast Aluminum
