jugalo180
www.moneyistherecipe.com
i have this problem with my art tube mp studio preamp. i can't seem to get the vocals boosted to a decent level without the pre adding extra noise. i recorded a track just what the mic off and the pre on and when i pressed the 20db gain there was tremendous noise. even without the gain there is noise when i either increase the in or out put volume. i have double sided quarter inch gold shielded cables from radio shack, is that the problem, the settings?, or is it the pre?
What are you sending the signal to from the tube preamp?
If it goes above -3dbFS, it will "crackle" (yuck). The distortion, if you didn't know better, sounds almost like digital clipping doesn't it? A very unpleasant "splatter". Using high/low impedance mics doesn't seem to matter.
(Blue Bear recommends the Grace 101)
