J
jonnyc
dgatwood said:I wouldn't recommend either the 1814 or M-Powered.
M-Powered has a low track limit (32 simultaneous), which I know I'd bump into constantly. You can upgrade to 48 by buying an additional piece of software, but really, why bother when there are much more flexible DAWs out there that don't lock you into a proprietary plug-in architecture, a particular brand of audio interface, etc.
As for the FW1814, my experience is that the hardware is very buggy at the FireWire PHY level. They don't play well with other devices---hubs, hard drives, other interfaces.... I spent hours trying to debug the thing and eventually concluded that it just doesn't work unless it is the only device on the bus. It usually works with one other device, but only if it is the first device.
The symptom of the failure is particularly bizarre---recording works, but the S/PDIF input and output go dead. I think the clock is going unstable, but I'm not certain. In any case, it's cranky enough that I would recommend any number of interfaces over it.
IMHO pro tools and both mpowered and le versions are great because they're propietory. I've used the more "flexible" softwares and compared to LE I've hated them. On top of all that I've already had several clients use me just for the fact I have PT. Some like coming to my place and laying down instruments and then going to a more professional set up to track vox and mix, and having pro tools makes it easy for them to do that.
