Pocket Operators Recording
  • Thread starter Thread starter greenise
G
greenise
Is anyone knows how to record the sounds from Pocket Operators from Teenage Engineering?
I tried to sync it with the sound card (Steinberg UR2MkII) and AUX (In/Out) of the Macbook pro laptop. But there is no any sound catched while connected with the AUX cable. :confused:
You would need to take a stereo cable (1/8" TRS) from the PO device into two separate line level inputs, plug those 1/4" inputs into the UR22mkii (I assume 22, not 2!).
Hosa YM-P434 Stereo Breakout 3.5mm TRSF to Dual 1/4" TS - 6" | Sweetwater
I.e., you do not set the UR22mkii as the audio input/output device and then bypass it going direct to the MacBook.
