G
girvan
Please help me layout my 12x11 room (photos incl.)
Hi,
Loc: NB, Canada
Budget: around $1000 CAN
Goals: Sound isolation and treatment for my small space. Live drums. Renovate for a control room for now with adding tracking room addition in future (maybe)
Trying to come up with a design for my small room. Below are photos and then some questions. I really, really, really appreciate your help.
Above: What I have to work with. Left is current. Right is what I plan to do - remove exterior door and window, board them up.
Exterior view. Red (pink) area is the space
This is what's above the room. If possible I could open that up (if to improve acoustics or mode of the room)
TL: Here's what the room looks like now. TR & BL: The current outer walls - Vinyl siding, boards, pink insulation and 1.4" press board.
What I know
I've read a lot on John Sayers site, this site and I'm 1/2 way thru Rod Gervais' book. I understand the m-a-m concept for walls. I understand DIY slat resonators (although I have no clue how to build to certain modes), bass traps etc... I realize airtight is key, caulking is key, I'm no pro but I'm starting to get it.
Where I'm lost
The Floor: It is dirt - 1' of air - 2x6 joist - plywood. Should I just add mass to this (mass meaning insulation and another layer of plywood)
The outside wall: I know that 2 leaf is the way to go so do I rip off the inner 1/4" ply and maybe reuse that on the floor or rip it on a table saw and add it between the studs on the outer wall. Should I cut 5/8 drywall and add that between the studs on the outerwall (there's no vapor barrier on this old house)
The ceiling: again for mass. Should I suspend drywall on RC or open it up and make a vault ceiling. The room is small anyway.
The layout: I know that symmetry is key. I also understand the benefits on non parallel walls. Should I stick with this:
as seen on JSayers site or go with something different. I need help on this layout.
Materials
I found a local supplier for Roxul Flexibatt® and/or Safe'n'Sound™ (Flexibatt around 70¢/sq foot [2'x4' @ 2"])
Also fabric to cover DIY traps (thick uphostery in many colors) is $3.96 - 56"W per meter (39").
I have free lumber (a lot of old barn boards) that I can rip into various sizes. I can get drywall and I have a box of acoustical caulking (not sure of the brand at the moment)
Thank you, thank you. I'll do my best to continue researching this. I really appreciate your help.
Hi,
Loc: NB, Canada
What I know
Where I'm lost
Materials
See what I mean? So, let us know what you are trying to do and we'll get on with the program, ok? Ok.
Music is a lifelong learning curve...how many more can I take on.
