sweetbeats
Reel deep thoughts...
So my dad has a line on one for $150 and he's been able to borrow it for a bit to give it a test drive. It all seems to work though he hasn't checked the record functions, but he says everything else is crisp...he did notice that the repro level range is less significantly less on one track vs. another. I talked to him about DeoxIT and cleaning switches. He also said that it doesn't auto-stop when tape winding ends so I told him to check and see if there is a mechanical or optical switch on one of the tension arms that isn't functioning and he then noticed that the left tension arm doesn't retract all the way...sticky grease maybe? It has full travel range, its just that the spring tension isn't enough to retract it all the way without help.
Questions:
Thanks!
Questions:
- Can anybody point me to any good threads or other web-based resources on this deck for my dad's benefit? Threads with technical helps or flags to trouble spots...maintenance tips, that sort of thing?
- Does this deck have removable amp cards in it with adjustment trimmers?
- Where is the best place to get basic parts for this deck (i.e. capstan belt)?
Thanks!
